September 21, 20206 yr I've run across 2 bugs since updating to Enpass 6.5.0 (700). These aren't showstoppers, but they are super annoying. I am now unable to double-click on an item to edit it. Double-clicking an item does nothing. When viewing a record (not editing), multi-line fields now have a massive amount of space added to them. At first, I thought all the other fields were getting deleted, but figured out that I could scroll down to get to them. Confirmed both of these issues on two different Macs, one running 10.15 and the other running 10.14. Please fix ASAP! Thanks!
September 22, 20206 yr Hey @ValZho Thanks for reporting this issue. We have found the problem and are now planning for the fix for it. Thanks!
September 26, 20206 yr I have the same issues AND I cannot change a "Section" (when saving any change switch back to first entry) or delete a section.
September 28, 20206 yr Hi @kuk, Sorry for the inconvenience caused to you. It would be a great help if you can explain this scenario a bit more, it will help in a clear understanding of the problem before further proceedings.
October 5, 20206 yr I have the same issues like "kuk" cannot change the name of Sections. If i rename a section and safe the changes, it dos not make the change at all. It still displays the old sections name. Edited October 5, 20206 yr by macudo
