September 23, 20206 yr Is Dark Theme not available in 6.5.0.701? I assumed it wasn't until I saw that production 6.5.0 on the Mac App Store is shown with a dark UI. Is it only available on macOS 10.14+?
September 24, 20206 yr Hey @100 Watt Walrus Thanks for writing in. Yes, it is only available on macOS 10.14 or later and it is also available in Enpass v6.5.0.701. Let me know if you have any queries. Thanks!
September 25, 20206 yr Author Thanks, but that's a little unclear. You say Dark is "only available" on 10.14, but say it's "also available" in 6.5.0.701. "Also" generally means "in addition to." So is 10.14 required for Dark Mode? Or does 6.5.701 have Dark Mode no matter what version of macOS is running?
September 25, 20206 yr Hey @100 Watt Walrus Apologies for the confusion. To enable Dark mode in macOS, device OS should be 10.14 or later versions of macOS along with the Enpass version 6.5.0.701(or later). If the Enpass version is 6.5.0.701 but the OS version of mac is less than 10.14, then the feature of dark mode won't be available. I hope this clears now.
