October 3, 20206 yr Filename: EnpassStartup.exe Threat name: Heur.AdvML.B Full Path: C:\Program Files\WindowsApps\SinewSoftwareSystems.EnpassPasswordManager_6.51.716.0_x86__fwdy0m65qb6h2\EnpassStartup\EnpassStartup.exe ____________________________ Threat type: Heuristic Virus. Detection of a threat based on malware heuristics. ____________________________ File Actions File: C:\Program Files\WindowsApps\SinewSoftwareSystems.EnpassPasswordManager_6.51.716.0_x86__fwdy0m65qb6h2\EnpassStartup\ EnpassStartup.exe Removed ____________________________ File Thumbprint - SHA: 8a12e8fba3ae62c28da666d9250e98986c43f7a8db8f82752990a051b0239580 File Thumbprint - MD5: 3bc7195b258d3f9a881659a1cab06708
October 5, 20206 yr Hi @Bonze I would hope this is a false positive, there have been incidences in the last couple of weeks with other AV suppliers. The Sinew staff will I am sure report the problem to Norton for correction as soon as possible.
October 5, 20206 yr Hey @Bonze Welcome to the forum! We've reported the .exe as a false positive to Norton team and hopefully they will release an update soon. Until then you can whitelist the application. Thanks!
February 8, 20215 yr I'm receiving this in Bitdefender On-Access scanning has detected a threat. The file has been deleted. C:\Program Files\WindowsApps\SinewSoftwareSystems.EnpassPasswordManager_6.60.770.0_x86__fwdy0m65qb6h2\EnpassStartup\EnpassStartup.exe is malware of type Gen:Suspicious.Cloud.2.auW@aSSl8Sdi
March 7, 20215 yr Hello. Same problem here with Norton an Enpass Desktop version 6.60.770.0 What can I do? Restore the file from the carantine? Has anyone already done this without risk? Greetings to the team Edited March 7, 20215 yr by Bleeddragon
March 12, 20215 yr Hey @Bleeddragon We have reverted you on your other forum post. Revert us if you have any queries. Thanks!
