October 8, 20206 yr There are still problems with MacOS High Sierra. The main screen is only gray. The difference to version 6.50 is that in 6.51 at least now the menu bar is visible. The docking window is visible and can be used. Please fix the rendering problems with High Sierra 10.13.6 on a Macbook Pro (2011).
October 8, 20206 yr Author Quick update: The problem only occurs with versions from the App Store. The file version from your website seems to work fine.
October 12, 20206 yr Hey @kobi Thanks for sharing your inputs. Will soon be releasing an updated version of Enpass, please stay tuned for upcoming update and share your findings with us.
November 2, 20206 yr On 10/12/2020 at 12:48 PM, Garima Singh said: Hey @kobi Thanks for sharing your inputs. Will soon be releasing an updated version of Enpass, please stay tuned for upcoming update and share your findings with us. Hi, after an update to 6.5.2, (System: MacMini with High Sierra) i do have the same problems. The main screen is only grey. I urgently need a solution. Is there already a date for the new update.
November 3, 20206 yr Hey @Hem While our team is trying to fix the issue, please refer to this link to use the previous build of Enpass. Also, stay tuned for the upcoming update of Enpass. Thanks!
December 29, 20205 yr we have end of december and still no fix for this available. how should mac appstore customers downgrade? they get only the broken version from the store. is it so difficult to re-release the old 6.4.x version in mac appstore? since 2 month enpass password manager on macosx high sierra from app store is unusable.
December 30, 20205 yr Hey @MOM20xx Welcome to the forum! Our team has fixed this issue of macOS platform in the v6.6.0 release of Enpass. Please wait for the stable version to be released and then share your findings with us. Thanks for the co-operation.
