October 12, 20206 yr Hello, I am using version 20.0 of Nextcloud and I can't synchronize my database. On my 2 Mac I can set up the synchronization wonderfully. The address is: https://cloud.myserver.eu/remote.php/dav/files/Clamsy/Apps/ My username: Clamsy My password: secret There it works. But if I want to synchronize the iPhone I get the error: "Could not connect to the specified WebDAV folder. Please check your username and password". Bypass SSL Verification is enabled. Username and password is correct. I have also tried an app password. Unfortunately also without success. What can I do?
October 12, 20206 yr Author It is always the same.... First you try for hours, days etc. and you don't get along. Then you write annoyed in a forum with screenshots etc. And then suddenly it works with the app password... It is to become crazy ;-)
October 14, 20206 yr Hi @Clamsy, Welcome to the forums! We have taken note of this and our team is now analyzing into the issue. Thanks!
January 22, 20215 yr Hi @Clamsy, Please share the following information so we can further investigate: Which model of the iPhone and the iOS version are you using? Which Enpass version are you using? Let us know if you are trying to Sync Primary vault or Secondary vault? Thanks for your co-operation.
