October 30, 20206 yr Hello, Every time I launch the W10 store client I have this message : I have to reconnect my icloud account to have iCloud sync works again... It's pretty annoying... Why is it happening ? Can it be different ? If not, I'll have to switch to another sync cloud... but I don't want to use OneDrive again because I had in the past to reconnect my OneDrive account every update of the client with restoring the data from the cloud... Thanks Miles
November 2, 20206 yr Hey @MilesTEG Sorry for the inconvenience caused to you. For security reasons, your iCloud session expires periodically. To avoid this, you first need to disconnect the sync with iCloud from Enpass settings, then again enable it, and you’ll be redirected to the iCloud login page. Here you just have to enable “Keep me signed in” as shown in the image given in this link. Hope this helps!
November 5, 20206 yr Author Hello, Ok Thanks, I'll give it a try next time I've got the message. But it's still annoying.
November 6, 20206 yr Hey @MilesTEG Thanks for writing in. Please let us know if you face the same issue again. Thanks!
February 3, 20215 yr Author Hello, I had to move to OneDrive Sync because the problem appears to often... And I had problems too with OneDrive Sync... : Now I have GDrive sync.
