November 1, 20206 yr I have been using autofill via the autofill framework in Edge, but sometime in October it has has stopped working. It still works fine in Chrome, so I'm wondering what the problem is since both browsers are Chromium based. I really don't want to use the accessibility workaround anymore, since I don't like the notification popping up all the time. The autofill framework has been around since Android Oreo, so it should be possible to use the proper version of autofill. Is this a problem in Edge or Enpass? Any way to fix this? Edge: Version 45.09.24.5087 Enpass: Version 6.5.2.404 Android 11
November 2, 20206 yr Hey @Laxor Welcome to the forum! You could try disabling and enabling Auto-fill in Enpass for quick troubleshooting. If you still face any problems, mention the particular sites or the apps where Enpass doesn't auto-fill on edge browser. Thanks!
February 2, 20215 yr The problem remains. Any news on this? In the meantime also the workaround with the accessibility notifications stopped working.
February 3, 20215 yr Hi @Gilrich, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Check if enabled Autofill in Enpass app and device Settings? Are you facing this issue on any particular website? If yes share the details with us. Thanks for co-operation!
February 5, 20215 yr @Pratyush Sharma Thanks for looking into this. Device: Samsung Galaxy S20 FE, Android 11 Enpass version: 6.6.2.458 Ever site is affected.
February 9, 20215 yr Hi @Gilrich, Thanks for sharing the details. We have taken note of this and our team is now analyzing into the issue.
February 11, 20215 yr Hey @Gilrich Thanks for your patience. Our team is working towards a fix so it runs as expected. Stay tuned for the updated version of Enpass.
February 15, 20215 yr I'm also having the same problem. I also have the Samsung Galaxy S20 FE 5G, Android 11. There is no problem using the Samsung browser, only edge.
February 16, 20215 yr Hi @DareFace, Thanks for reporting this issue. We are already aware of this issue and our team is working on it. Stay tuned for the updated version of Enpass.
