November 10, 20179 yr Is there a way to delete duplicates? If not would it be possible to export then use a third party script/app to remove duplicates? Or would doing that wreck the file stucture? Thanks
November 10, 20179 yr Author I exported as a csv as that way the info was on one line. Ran a one liner to remove duplicates. Then when I went to import I could find no easy way (maybe I just missed it). So I just erased everything and reimported my LastPass DB.
November 13, 20179 yr Hey @BeZazz I'm glad that you found a workaround. However, I was wondering, how did you end up with the duplicate entries in your DB? On 11/10/2017 at 2:25 PM, BeZazz said: Is there a way to delete duplicates? The option to remove duplicates is currently not available in Enpass but has option to import through generic CSV. Cheers!
November 13, 20179 yr Author While I did not find that link, I did do that and Enpass kept locking up. Possibly due to the amount of passwords I was trying to import (about 1,500)
February 22, 20188 yr I just wanted to throw in the desire for a 'Find duplicates' tool again. Aside from the obvious accidental duplication, I think many potential users evaluating Enpass run it side-by-side with their current password manager at least initially. Inevitably, there will be duplicates or additions to Enpass that may not be in the other manager, preventing the user from just deleting the full Enpass DB and starting over. Just an upvote for an option to find duplicates.
