November 15, 20206 yr The latest release of macOS Big Sur introduces a new overall design, and specifically changed the entire app icons set. Every day, more and more third-party app developers are updating their app to support the latest features of macOS Big Sur, like Widgets or Apple Silicon support. But a very basic and simple change that would dramatically improve the way Enpass looks is if its icon was updated to match the new design. Since all app icons are basically now square with rounded corners, the very classic circle of Enpass looks quite odd in the new application bar. Could the Enpass macOS app icon be updated to match the new design of macOS Big Sur?
November 16, 20206 yr Good point - hope they do that though i figure a lot of people (like myself) use the keyboard shortcuts and keep the app icon hidden from the dock
November 17, 20205 yr Hey @John Doe & @Lyro_1 Thanks for using Enpass and sharing your views. We really appreciate you for sharing this valuable suggestion and the same has been noted. Thanks!
