Preferences not getting saved
Hey :)
Running 5.6.2 of the Windows bridge app (from the Windows store). Seems like none of my preferences are getting saved? I want to enable minimize to tray and enable extensions, but every time I quit the app, these settings are reset.
Anyone else getting this?
Thanks!
Hey @kLy
That shouldn't be happening! Can you please try re-installing the app and try again. If the problem persists, please let us know the version and the build of Windows that you're using so that we can help you better.
NOTE: Before re-installing, please make sure that you've got a backup of your data or synced it to a cloud.
Cheers!
  • 3 weeks later...
Hello all,
Same problem here. BUT I'm running windows pro insider version 17063. kLy, did  you succeed to fix the problem ?
Happy new year anyhow :-)
Edited by guizop
