December 12, 20205 yr Hey there, as written in this post, I had some bugs where enpass showed me weak or identical passwords probably based on obsolete database entries (I initially imported a csv from my previous password-safe-solution). So today I ended up rebuilding my vault from the ground up with the exact same entries as before. That was a 1,5 hour job of copy / paste. As a result, I'm not only solving the bugs but also ended up with a over 80% drecreased database size . So I was wondering: Is there any (planned) feature to delete obsolete database entries or to "sanitize" the database? While building up a history of database entries makes sense, you will probably end up with a massive database after some time without any feature to clean up obsolete or faulty entries.
December 14, 20205 yr Hi @Trendsetter Thanks for the analysis and sharing it. Currently, deleting password history feature is not available. However, it is aligned for implementation in future.
