January 22, 20188 yr I am getting this Unexpected Error Crash almost 2-3 times a day since the latest version upgrade about 1-2 weeks ago, I am using the version from the Microsoft Store together with the Edge extension, to me the latest version is extremely buggy, if I add the connection error to it. Sometimes it will crash even without this message. Edited January 22, 20188 yr by brosenz
January 23, 20188 yr Author At this point in time, between this crash and the connection error of the extension, Enpass it is pretty much unusable, I have so many crashes a day
May 28, 20188 yr Same for me. This use to only by on my Surface Pro 3 1803 build it would crash after a few minutes of fresh boot. I've noticed if I leave the window open it doesn't crash as often. This issue started to appear on my desktop now too which is also 1803. Is there a plan to release a fix soon or is 6.0 version coming in the next few weeks and it has been fixed there?
August 6, 20188 yr Same here. Error occurs whenever I'm deleting an entry. This is happening even without Edge extension installed.
August 6, 20188 yr Hi @blaaaahblahblah, Sorry for the trouble you're going through. Please share some more info so that we can investigate further. Which device (along with OS version) are you using Enpass? Which Enpass version are you using? Which cloud services are you using to sync? Are you facing this problem while editing the credentials of any item? For Testing Purpose: Please turn off the internet connection and open Enpass and delete one dummy item and let me know if you're facing the same problem. Thanks for your co-operation.
August 12, 20188 yr Hello, Which device (along with OS version) are you using Enpass? Windows 10 Pro ,Version 1803, Build 17134.165 Which Enpass version are you using? 5.6.19 (5548) Which cloud services are you using to sync? None Are you facing this problem while editing the credentials of any item? No, so far only delete.
