move item to a different vault
I saved an Item to my Primary Vault, but I need to move it to a secondary Vault; how can i make it?
Hey @MirkoMK
To move an item in another vault on desktop, make sure you have selected the particular vault in which the item is. Now right click on the item and you will get an option 'Add to vault', select the vault in which you wish to move the item. However, you can move the item on mobile devices by using the below steps-
  • Go to the detail screen of the item → Tap on more options (3-dots) → Tap on 'Add to Vault' → Select the vault where you want to move/copy the item → Tap on Move/Copy to add the item to the selected vault.
Let me know if you have any queries while doing so.
Thanks!
Hi Garima,
many thanks: it's working.
//Mirko
