February 26, 20215 yr Hey guys, is it normal that when u restart the MAC u have to enter the masterpassword instead using Touch ID? I have the option to login with touch id AFTER entering the masterpassword once. Thanks Edited February 26, 20215 yr by HansiBindi
February 26, 20215 yr Author I found out that every time i "close the program" i have to reenter the master password. After entering it i have to option to use touch id... thats not normal i guess? On my other Mac where i dont have installed Big Sur this problem is NOT accuring! Edited February 26, 20215 yr by HansiBindi
March 2, 20215 yr Hey @HansiBindi Thanks for writing in. The possible reasons due to which you are not able to use the full-time Touch-ID could be that you are using the Enpass Website version on your macOS or your device doesn't support the full-time Touch-ID. 1- To confirm Enpass version, please check the Enpass version using the steps: Open Enpass > Click on ‘Enpass’ given in the menu > Tap on About Enpass and share a snapshot of the same. 2- To know if your device supports Full-time Touch-ID, check the message below the Touch-ID option in the security settings of Enpass as attached in the screenshot and let us know if it is any different.
May 24, 20215 yr Hi I am having same issue on my new M1 iMac, why it is required to enter password after a restart ?, and can't just use my Touch ID. Andy Edited May 24, 20215 yr by Andy Blackburn
May 25, 20215 yr Hey @Andy Blackburn Welcome to the forum! Please try disabling and re-enabling the Touch ID. The message 'You can always use Touch ID to unlock Enpass' should appear on screen below the Touch ID option.
