February 27, 20215 yr Hi there in Windows there is the option that a certificate is appended to the masterpassword to unlock the vault. Does this also work with the iOS app? If so, how? Thanks Andreas
March 1, 20215 yr Hi @Andreas2, Thanks for writing in. If I have understood correctly, you want to add Keyfile to the iOS device. Yes, you can use the same keyfile in iOS device which you generated on desktop. To do so, please refer to this user manual. Hope this helps!
