Web extension not working on Firefox 58 / Manjaro
I have the desktop app open.
When I click the web extension button on Firefox, it quickly redirects me to the configuration error page, asking me to enable the web extensions on the settings from my desktop app.
However, I do have it properly configured (see image attached).
Details:
Browser: Firefox 58
OS: Manjaro Cinnamon Build
Enpass desktop: 5.6.5
Enpass for Firefox: 5.5.2
Hi @hbarcelos,
Sorry for the trouble you are facing while using the Enpass extension on Firefox browser. Please make sure you have  "lsof" dependency installed on your system.
If the problem still persists, please run lsof -i:10391 command in the terminal and share the output via support@enpass.io
10391 is the port number here.
If it shows no output (blank), please try with other port numbers between 10391 to 10395.
Also please let me know if you are facing the same problem with the other browsers (Chrome/Opera) as well.
Thanks for your co-operation!
Hi, @Anshu kumar, thank your for your answer.
In deed, I didn't have `lsof` installed. Installing it fixed the issue after I restarted the browser.
P.S.: Probably you should include a warning in the installation wizard.
Edited by hbarcelos
