April 9, 20215 yr Hi, is there a chance to use autofill funcion with this page? DForum Thanks Edited April 9, 20215 yr by Tobi
April 12, 20215 yr Hey @Tobi Thanks for writing in. Yes, you can auto-fill on the desktop using the browser extensions. Enpass Browser extension/plugin works with chrome, Firefox, safari, edge, opera browsers to auto-fill the details. Once installed the Enpass extension with the browser, open the particular webpage and fill the login details. Now when you click on submit/login, Enpass will auto-capture the website page and login details using the extension. To do so, please make sure that Ask to save new logins from the Enpass Browser Settings is enabled. Once the details get saved in Enpass, you can click on the Enpass extension directly after opening the specified webpage and fill the details from the plugin. Or you can manually add the item detail within Enpass and use the Enpass extension to fill it in the particular webpage. Let me know if you have any concerns while doing so.
April 12, 20215 yr Author Hello @Garima Singh, thank you for the answer. But unfortunately that was not my question. I have with the page that problem that the data are stored but when calling the page the field Password is always empty and thus the login does not work. On most others I do not have any issues, but hete will enpass autofill not work corectly
April 13, 20215 yr Hi @Tobi Apologies for the misunderstanding. To check this issue better, please share below details- On which device and OS are you having this issue? Which Enpass and Enpass extension version you using on the same device? Which browser version you using? Thanks!
April 13, 20215 yr Author Hello @Garima Singh, 1. Windows 10 with all updates 2. 6.6.1 (804) 3. The same issue with Edge, Firefox and Chrome Cheers
April 15, 20215 yr Hey @Tobi Thanks for sharing the required inputs. We've been able to reproduce the issue and assigned it to the team for a fix.
May 27, 20215 yr Hey @Tobi Thanks for writing back. The issue has been fixed in the coming Enpass Extension and the same will be available in the near future.
November 20, 20214 yr Author Hey @Garima, after last Enpass Update (2 or 3 days ago) Autofill is again not working on this WEB-Page (see first post)
