SYNCING
I am attempting to sync enpass between a Mac Mini and a MacBook Pro.  I have set up each to save the data in my iCloud account.  I've used the Tools > Sync menu command but nothing seems to be happening.  Both computers are connected to a single iCloud account with the same AppleID & password.  They are also connected via a local wi-fi network and both access the Internet through the same router.
I would appreciate any advice that may help me to solve this problem.
Thanks,
roger
Hi @nonsibicunctis,
Sorry for the inconvenience.
Please let us know are you getting any error message or code during sync? To check, goto Preference --> Vault --> Select Vault --> Check Sync.
