Two FEATURE REQUESTS: Dark mode and creating templates from existing Items
Hi folks,
Two feature requests (macOS):
1) Dark mode without having to turn it on system-wide. I'd like Enpass dark, but I don't want to have to deal with dark TextEdit, dark Contacts, etc.
2) Editing templates should be done in a UI that looks like an item layout, not in a cramped Preferences window that bears almost no resemblance to what the template will create when it's used.
In fact: 2.5) When creating a new template, it should be possible to select an existing Item and Save As > Template. And it should be possible to make that template a default.
I don't use Enpass templates because it's way too much work. Instead I have an Item I call (Template) — the parentheses keep it at the top — in which I've created and customized all the fields I use, and removed all those I don't. When I need to create a new item, I just select that item and CMD+D to duplicate it. It's a one-step process, unlike using the build-in templates, which requires several steps.
Cheers.
Edited by 100 Watt Walrus
Hi @100 Watt Walrus,
We appreciate for your continuous effort in helping us with the suggestions for improvement. We have taken a note of your feedback and we might implement such in the future versions of the app.
