August 12, 20215 yr When selecting an entry within Enpass 6.6.2(827), rather then seeing the entry with the password; it's blank ? Edited August 12, 20215 yr by RoadRunner
August 12, 20215 yr Hi @RoadRunner, Welcome to the Enpass Community. I have forwarded this issue to the concerned team for further investigation. I'll let you know as soon as I have any updates for the same.
August 13, 20215 yr Hi @RoadRunner, Thank you for reporting this issue. I would like to share that this issue has been successfully reproduced on our end and will be fixed in upcoming builds. I appreciate your time and support.
August 14, 20215 yr Author 20 hours ago, Gulshan Dogra said: Hi @RoadRunner, Thank you for reporting this issue. I would like to share that this issue has been successfully reproduced on our end and will be fixed in upcoming builds. I appreciate your time and support. I need to access passwords within Enpass, can Enpass not release a patch for this in the meantime.
August 16, 20215 yr Hello @RoadRunner! You can access your data by increasing your Enpass window width or maximizing it. Let me know if that works for you.
August 23, 20215 yr Author Hi, this works; as well as I assume there has been a new release since this issue was posted, as it appears to be fixed ? Edited August 23, 20215 yr by RoadRunner
August 23, 20215 yr Hello @RoadRunner! Glad to know that now you can access and see your data. I would like to inform you that this is in our queue and will be fixed in the upcoming updates. Your patience is highly appreciated here. Thank you.
