August 21, 20215 yr Hello, Can we use Enpass Portable as a backup if the Enpass Desktop have any issue to open ? I mean working with both if necessary ? What do we need to do ? Do we need to sync Enpass Desktop and Portable databases ? Thanks for your opinions.
August 23, 20215 yr Hello @DesignT! Welcome to the Enpass Forum. Yes, If the Enpass Desktop app has any issues, you can use Enpass Portable as a backup. Also, if necessary you can use both of them together, and to keep the data updated, you have to sync your data with the cloud account. For more information, I would suggest you download the Enpass portable, and here are the instructions to set it up.
