August 23, 20215 yr Hi Team, Sorry if this is in the wrong place as I wasn't sure where to put it (you guys don't have a "features" area for comments). My issue is that almost every password I set (I use the auto password generator) is marked "weak", however many passwords on sites don't support longer/more complex ones, and there are many times I need "plain English" type passwords even though I know they are less secure. It would be REALLY good if you could specify what you consider a "weak" password globally. There may also be reasons for wanting your passwords to be what enpass considers "weak". While I'm happy to have a flag - being able to control when that flag appears would actually make this functionality far more usable. If you could specify less than number of characters + no special characters + no numbers + no caps - dictionary words (or some combination of this) as being "weak" it would be much easier for me to determine which of my passwords were actually "weak" in all cases.
August 23, 20215 yr Hi @NicT Welcome to the Enpass Community! You can refer to this link in order to learn more about how Enpass calculates strength of a password - https://www.enpass.io/docs/security-whitepaper-enpass/miscellaneous.html#password-strength-estimation Also, You can set Enpass to exclude some passwords from audit, Please follow these instructions https://www.enpass.io/docs/manual-desktop/customize_fields.html#exlude-from-audit Thanks.
