October 15, 20215 yr When using the global system shortcut to bring up the assistant and copy a password (or username or whatever), it would be nice to have the option to auto hide the enpass window. This way you can quickly lookup a password for use within an application (e.g. iterm). It would be great to have this as a configuration option.
October 18, 20215 yr Hi @rburgst, Thank you for reaching out to us. The system wide hotkey lets you launch the Enpass anywhere in the system, Enpass Assistant will pop-up right there to give you quick access to your Enpass data and then by simply clicking anywhere outside the Enpass window it closes the app. Although, I have duly noted your feedback to auto hide Enpass app after copying the database and it has been forwarded to the concerned team for further consideration. Cheers!!
October 19, 20215 yr Author @Gulshan Dogra thanks for the quick reply. The thing is I want to avoid having to reach for the mouse. Thats the whole point of the global system hotkey.
