October 28, 20215 yr Hi there, As of this morning, I am getting an authentication error with OneDrive Sync. Logging in via Chrome results in the attached error. I was forced to switch to Google Drive temporarily. Can you please advise? Thank you!
October 29, 20215 yr Hi @dejanh, Thank you for reporting the presence of this issue. I have shared it all with the concerned team for further investigation. Your patience is highly appreciated here. #SI-2405
November 1, 20215 yr Author Hi Manish, Thank you. Do you have any update for me regarding this issue? Dejan
November 17, 20214 yr Hello @dejanh, I would like to share that our team has tested this issue on multiple machines along with various Enpass versions and find it working as expected here. Could you please share the details of Enpass version (Store or Website) and OS information? #SI-2405
March 17, 20233 yr Run Repair on your libraries In the taskbar notification area, right-click or press and hold the OneDrive menu icon. , and then click Repair. In the dialog box, click Repair. Repair reports your progress until all sync connections are reset. Click Finish. Regards, Rachel Gomez
