December 10, 20214 yr I'm using mailbox.org as my e-mail provider and want to connect Enpass to my mailbox.org-Clouddrive via WebDav. There is a KB article creating a WebDav connection and a hint when working with Enpass. https://kb.mailbox.org/display/MBOKBEN/WebDav+for+Windows When using Enpass this should work: https://dav.mailbox.org/servlet/webdav.infostore/Userstore/Lastname, Firstname/ENPASS But it doesn't. I get the error message that it's not possible to get a connection and I should check my username and password. But username and password are correct! Anyone using Enpass together with mailbox.org and could help here?
January 28, 20224 yr Author After further testing, I found the solution for me! With this WebDAV link, I'm able to sync to mailbox.org in Enpass: https://dav.mailbox.org/servlet/webdav.infostore/Userstore/Lastname Firstname/ I didn't have to put the folder "Enpass" at the end of the link. It was created automatically. Maybe this helps others to sync vaults with mailbox.org via WebDAV.
January 31, 20224 yr Hi @DenalB I'm glad to hear that! I appreciate you notifying us that the issue you were facing has been resolved. If you have any further questions or concerns, please do not hesitate to contact us at - support@enpass.io, and we will be happy to assist you!
April 3, 20233 yr Connecting a vault with Mailbox.org using WebDAV in Enpass Go to Settings > Vaults. Choose the vault to connect with the WebDAV, and then click Connect. ... Select WebDAV from the list of syncing options. Enter your Mailbox.org login credentials. Click Connect. Regards, Rachel Gomez
October 11, 20233 yr Hi, is there an update for the URL? I tried both versions above and many other I found in different discussions, but nothing worked for me. Tested on iOS and Android.
October 12, 20233 yr Hi @JuliusH4 To assist you better with your query, kindly elaborate a little more on the issue you are facing and also share the below details with us - The version of the Enpass app and OS you are using on all your devices. A screenshot of any error occurring would be helpful
