Custom icon for secondary vault not stored (iOS)
If you modify the icon for a secondary vault with a custom defined icon, this setting will not be retained after the restart of the Enpass app. If you select one of the built-in icons everything works fine. Please refer to the series of screenshots attached to this post ...
Edited by RMJM
screenshot had wrong position
Hello @RMJM,
I would like to share that we have tested it and found it working as expected. It would be extremely helpful if you can share the details of the Enpass version and iOS version so that we can investigate further.
O.K.: to clarify: when I write "Terminate Enpass" I mean terminate completely by swiping up the app:
Hello @RMJM,
Thank you for sharing the details. I have forwarded it all to the concerned team for further investigation. Your patience is highly appreciated here.
#SI-2544
  • 3 weeks later...
Hello @RMJM,
I want to share with you that we have reproduced this issue, and our team is working on resolving it. Our team greatly appreciates your patience.
