Restore from Timemachine Backup?
I had to set my mac up again, clean installation for new M1 Mac.
However, I forgot to make a backup of the Enpass data.
Is there any way to copy the old install to my new installation and just start through with it?
Thanks
Carsten
Hi @chilber,
Welcome to the Enpass Community.
Your data is automatically backed up on the device if you have enabled the Enpass Autobackup option previously. You can then restore your database from there for more information visit to this link.
If you are using a cloud service for synchronization, you may also Restore from cloud.
Hi @Gulshan Dogra,
thanks for your answer. Where would this file be located if it exists? In the link you have posted, they only tell how you backup a file you know of :-)
Thanks
Carsten
@chilber,
If the backup file exists, take a look at the following location on your device and look for the Backup folder.
  • /Users/$Username$/Library/Containers/Enpass/Data/Documents/
                                                OR
  • /Users/$Username$/Library/Containers/in.sinew.Enpass-Desktop/Data/Documents/
