March 25, 20224 yr There seems to be a glitch in Enpass, where it doesn't lock during System Lock (Win-key + L) even it the setting is applied as shown below. The bug occurs (for me) only if I initially unlock Enpass through the Helper Window in System tray. If I initially unlock via the main Windows, the "System lock" works as expected. Enpass 6.7.4 (934) Windows 11 21H2 Fulltime Windows Hello-activated
March 28, 20224 yr Hi @Ivarson I have forwarded your concern for further testing to our dedicated tech team. As soon as they update me, I will be sure to notify you on this forum. Thanks for your patience in the meantime. #SI-2699
March 30, 20224 yr Hi @Ivarson We have reproduced the issue on our end, due to which the Enpass application remains unlocked when it is initially unlocked through the Helper Window after unlocking the system. We are currently developing a patch to fix this problem, which will be released in the coming updates. Thanks for your patience while we work on it.
September 26, 20224 yr Author Im now on 6.8.2 build 1084 from Microsoft Store, and now there's no Locking of Enpass neither when unlocking through main window nor helper window.
September 26, 20224 yr Hi @Ivarson I certainly understand that it is taking us a while to fix the reported issue. Unfortunately, I am unable to share an ETA for this issue. Rest assured that we are working on a solution, and I have also shared your comments with our development team as feedback. Your patience in the interim is appreciated.
September 26, 20224 yr Author thanks, it wasn't critisism, I just made sure this didn't slip through since it's security matter, vaults remains decrypted and opened through computer standby and etc. Ctrl+L is one's friend now.
