March 27, 20224 yr There's a clear warning when there's no internet access and sync fails, a red banner at the top. But when there's a sync conflict in a vault, there's only a red spinner top left that flashes vaguely in red. In Android app it's even hidden until you use the flyout menu. If I where to get my parents to use Enpass, they would never even notice that and their vaults wouldn't be synced. I don't even understand why the user has to intervene here, and press "Merge" since there are no options. But if it's needed at least make it pop out
March 28, 20224 yr Hi @Ivarson, Thank you for reaching out to us. I have duly noted your feedback and your suggestion has been forwarded to the concerned team for further considerations. #SI-2701
March 31, 20224 yr Author Like in this instance, what's the cause and what's the purpose of suspending sync demanding "approval" hidden in the vaults settings. The same amount of items, only that the cloud-vault was changed from another source, which is the whole point of sync. And the same now has to be done on other Enpass-installations sharing that vault. See the "red" ring around the icon next to the vault-name? me neither. Edited March 31, 20224 yr by Ivarson additional info
May 15, 20224 yr Author @Gulshan Dogra, there was improvements regarding showing conflict-warnings in Enpass 6.8, kudos for that! Im still curious though, why there is a need to manually have to resolv a conflict at all (by clicking 'merge'), like in the above post. Could you shed some light over that?
May 16, 20224 yr @Ivarson, Thanks for reaching out to us. Only a single vault can be synchronized over a single cloud account that contains the database of the single vault. If you try to sync another vault over the same cloud account, then you have to merge the databases of the previous vault and the new vault, thus the merge option you see. Your cloud always contains a copy of same encrypted vault database as on your device. A copy of your encrypted data is downloaded on your device where is gets decrypted (locally) for real sync operation to merge changes. Afterwards, it gets encrypted again and uploaded back to the cloud.
May 16, 20224 yr Author 7 hours ago, Gulshan Dogra said: @Ivarson, Thanks for reaching out to us. Only a single vault can be synchronized over a single cloud account that contains the database of the single vault. If you try to sync another vault over the same cloud account, then you have to merge the databases of the previous vault and the new vault, thus the merge option you see. Your cloud always contains a copy of same encrypted vault database as on your device. A copy of your encrypted data is downloaded on your device where is gets decrypted (locally) for real sync operation to merge changes. Afterwards, it gets encrypted again and uploaded back to the cloud. Thank you, but that's not relevant here. There's no attempt of reusing a "cloud-account" for multiple vaults, same cloud-provider, yes, but never the same accounts. Today I even got a conflict on a vault syncing to a local folder. Something is triggering Enpass into seemingly unneccesary conflicts (that always seem to resolv just fine after pressing "merge" manually;
May 18, 20224 yr @Ivarson, Please share the following details so that I can get this issue investigated by our concerned team. On which device (along with the OS version) are you using Enpass? Which Enpass version are you using? Is is a store version or website version?
May 18, 20224 yr Author 1 hour ago, Gulshan Dogra said: @Ivarson, Please share the following details so that I can get this issue investigated by our concerned team. On which device (along with the OS version) are you using Enpass? Which Enpass version are you using? Is is a store version or website version? 6.7.1 and 6.8.x Android 11, iOS, Windows 11, Ubuntu 22.04... Come on, it happens on ALL devices i've encountered, and both in the latest 6.7-versions as well as in the current 6.8-versions..
May 19, 20224 yr @Ivarson, Thank you for writing back and sharing the details. I have forwarded the same to the concerned team for further investigation. I’ll let you know as soon as I receive any updates from the team regarding the same. In the meantime, your patience and support are highly appreciated. #SI-2843
August 18, 20224 yr @Ivarson Thank you for reporting the presence of this bug, It has been identified as an issue by our backend team, and they are currently working on it. #SI-2843
