How to make sure to always remember to keep Enpass always in sync whenever going back a previous computer image with Macrium Reflect ?
Is it possible without cloud ? If so how?
Edited by ng4ever
Hi @ng4ever,
Thank you for reaching out to us.
I would like to share the sync timings of Enpass.
  • Every time you unlock your Enpass keychain, an auto-sync is initiated. (If Sync is turned on).
  • Auto-sync also happens after every 15 secs, while the app is in the foreground.
Wi-Fi Sync in Enpass lets you sync data between devices connected to same network. To use Wi-Fi Sync, you need to start Wi-Fi Sync server from a desktop device on the network and host the vaults from that desktop to which other device on the network can connect and sync. For more information refer to the below-mentioned links:
Wi-Fi Sync - Enpass
Troubleshooting Wi-Fi Sync - Enpass
I'm not familiar with Reflect, but if you don't want to use any sort of cloud synching, you can use local WiFi sync, though that will require having another desktop instance of Enpass running in your local network.
https://www.enpass.io/wifi-sync/
Alternately, you could set up a NAS and use that with WebDAV to serve as the central sync point.
