April 28, 20224 yr Monterey 12.3.1, Enpass 6.7.4 In the Windows section of this forum I found a post with the title "Enpass freezes, then only works after PC reboot", posted on november 7th, 2021. I have the same problem on a Mac: Enpass freezes very frequently, after which there is no other solution possible than quitting and then restarting the application. This is really a very annoying bug, that should be addressed immediately. Edited April 29, 20224 yr by Timotheus
April 29, 20224 yr Hi @Timotheus, Thanks for reaching out to us. The concerned team has been notified of your feedback and a further investigation will be conducted. In the meantime, if this problem persists, please restart the application. I appreciate your patience and your support in advance. #SI-2758
April 30, 20224 yr Author I really do hope this problem will be solved quickly; if not, I'll have to look for an alternative.
May 3, 20224 yr @Timotheus, Could you share the following information with us so we can diagnose the problem and further assist you. Which Enpass version are you using (Is it a store version or website version)? Total number of vaults and items in your Enpass? Which cloud service you are using for synchronization? #SI-2758
May 4, 20224 yr Author 1. I downloaded the application from your website. 2. I have one vault only. 3. My synchronization is exclusively local: wifi between desktop and iPhone. No cloud service.
August 18, 20224 yr @Timotheus, Thank you for sharing the details. Please update the Enpass to its latest version and share your findings with me. If the issue still persists then please share the total number of items and vaults you are stored in Enpass.
