May 19, 20224 yr This option was removed in recent v6.8. Please restore it ASAP. cmd+c Edited May 19, 20224 yr by aaadeji
May 19, 20224 yr I just tried this on macOS Monterey with the store version of 6.8.0 and I was able to copy things out of notes via the keyboard shortcut and also by right clicking on the selection and choosing Copy. I tried via the menu bar assistant and that worked, too. Can you provide more information about your setup and macOS version? It will be hard for them to fix something if they can’t figure out how to replicate it.
May 20, 20224 yr Hi @aaadeji As suggested by @Discordant, kindly share the below details with me and I'll have this investigated for you - The version of the OS you are using. Have you downloaded the Enpass app from the Mac App Store or our official website? Are you facing this issue on multiple devices? Are you receiving an error when trying to perform the copy action? If yes, kindly share a screenshot of it as well.
May 24, 20224 yr Author I have more info into that bug – it has a pattern For 1st copy, you have to press the copy shortcut (cmd+c) exactly 3 times. For 2nd copy, you will copy the text after first shortcut. For 3rd copy, you will have to press 3 times. For 4th copy, you will have to press only one time. ...and so on... Monterey 12.3.1 Enpass 6.8.1 (Mac App Store) > Are you facing this issue on multiple devices? I can't check it, sorry. Edited May 24, 20224 yr by aaadeji
May 24, 20224 yr Hi @aaadeji Thank you for sharing the details. I have forwarded your concern to our dedicated testing team and will be sure to notify you on this forum as soon as I receive any updates on this matter. Your patience in the meantime is appreciated. #SI-2860
May 25, 20224 yr Hi @aaadeji We have reproduced the bug due to which this issue is occurring. Our development team is now working on fixing it and a patch addressing this issue will be released soon for the future Enpass versions. We appreciate your support and patience while we work on fixing it.
June 22, 20224 yr Hi @aaadeji Our dedicated development team is still working on fixing this bug. Unfortunately, I will not be able to share any ETA for the same but rest assured, this bug is on our roadmap to be fixed. Thanks for your patience in the meantime.
