June 7, 20224 yr Whenever I go back a image with Macrium Reflect sometimes I lose the previous logins/passwords I added. Only a few but still. Maybe I am doing it wrong ? Any solution ? Sure I could backup manually the local files but then there is no way to replace them easily to Enpass after going back a previous image. At least not that I know of.
June 9, 20223 yr Hi @ng4ever, Thank you for reaching out to us. You can setup the synchronization of Enpass your database with any of the supported cloud service. If you are using Wi-Fi Sync, then start the Wi-Fi Sync server on some other desktop device and use your Macrium Reflect as a Wi-Fi Sync client device.
