June 21, 20224 yr I have completely reinstalled Enpass. Unfortunately, it always crashes after a few seconds. The behavior did not exist before until version 6.7.4! Attached is the crash report. ------------------------------------- Translated Report (Full Report Below) ------------------------------------- Process: Enpass [1600] Path: /Applications/Enpass.app/Contents/MacOS/Enpass Identifier: in.sinew.Enpass-Desktop Version: 6.8.2 (1082) App Item ID: 732710998 App External ID: 850164998 Code Type: ARM-64 (Native) Parent Process: launchd [1] User ID: 501 Date/Time: 2022-06-21 21:51:50.1846 +0200 OS Version: macOS 12.4 (21F79) Report Version: 12 Anonymous UUID: 88945697-49E3-18E4-02B2-2239B2CC44E7 Time Awake Since Boot: 280 seconds System Integrity Protection: enabled Crashed Thread: 42 Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000018 Exception Codes: 0x0000000000000001, 0x0000000000000018 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11 Terminating Process: exc handler [1600] VM Region Info: 0x18 is not in any region. Bytes before following region: 105553552211944 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL UNUSED SPACE AT START ---> MALLOC_NANO 600019fc0000-600020000000 [ 96.2M] rw-/rwx SM=ZER
June 22, 20224 yr Hi @Ole I have forwarded this concern to our dedicated testing team and will get back to you soon with an update. Your patience in the meantime is appreciated. #SI-2946
June 23, 20224 yr Hi @Ole We are looking into the concern reported by you, but our team of experts require some additional information in this case - Number of Vaults and Items you are using. Are you using any cloud sync or Wifi sync? Does the crash occur after any specific step? Life after editing an Item, creating a new Item etc? We appreciate your co-operation in this matter.
June 26, 20224 yr Author i have 19 vaults: 1 iCloud, and 18 WebDAV using only cloud sync via iCloud and WebDAV the app crashing when open, regardless what I do - when I do nothing, it crashes too. It seems to crash, when the app tries to sync with the vaults When I set up the app new with iCloud private relay off, it worked till I turned private relay on. Then the crashes appear. Then I deleted the app and all preferences und set up new again with private relay on. It worked 2 days, then it crashed again. I changed nothing. It may have something to do with this function, but what do I know? Enpass is not usable for me since then, but I need it. Edited June 26, 20224 yr by Ole
June 27, 20224 yr Hi @Ole Thank you for the details. I have forwarded them to our testing team for a thorough investigation of this issue and will get back to you soon with an update.
June 28, 20224 yr Author I reinstalled Enpass again and put only WebDAV-Vaults in. Now this are only 11 vaults. It crashes again, after I went up from 5 to 11 vaults. Thread 24 crashed with ARM Thread State (64-bit): sp: 0x000000016db09290 pc: 0x0000000102c6278c cpsr: 0x80001000 far: 0x0000000000000018 esr: 0x92000006 (Data Abort) byte read Translation fault
July 9, 20224 yr I suspect I have the same problem with Enpass 6.8.2 (1081). When I launch Enpass and enter the main vault password, Enpass crashes immediately with no error message or other response. When I launch Enpass again and enter the main password, Enpass opens as expected. I have observed this behavior on three Macs: MacMini from 2020 and MacBook Pro from 2015, both macOS 12.4 and an old MacBook Pro with macOS 10.15, all Intel-Macs. Enpass contains only one data vault on each, which is currently synced via Google Drive. On macOS 12.4 I installed the version downloaded from the website and on the MacBook Pro with macOS 10.15 I installed the version from the MacApp Store. So it doesn't seem to make any difference regarding the website vs. MacApp Store version in terms of crashes for me. The problem only exists since the last two or three updates of Enpass. Unfortunately, I cannot find a crash report in console.app
July 14, 20224 yr I have the same problem. since the last update of Enpass (6.8.2 1082) on my iMac I have extreme problems: * Unlocking via TouchID keeps failing * Then I enter my master password and it says it's the wrong one, I enter the exact same password the second time it works. The next time again the first time error then it works. * I had deposited 5 vaults. Now there are only 2 safes left * Now I wanted to add my vaults back and sync via WebDav *** Now I get the following error message sync error Two tresors cannot be connected to the same account to sync data. But I use a separate user on the WebDav server for each safe I have the feeling that there are similar bugs as a few months ago in the iOS version after an update.
July 15, 20224 yr Hi @compoundbow83 Regarding unable to connect two tresors to the same account to sync data, our dedicated team is already aware of this issue and is working on resolving this bug. As for the Touch ID not working properly and Enpass app not recognizing the master-password for the first time, kindly create a manual backup/set up synchonization on your device and then re-install the app. After restoring your data, please enable the touch ID again. Let me know if the issue persists.
July 15, 20224 yr I have re-install the App. And even after that, Touch ID doesn't work and every time Enpass doesn't accept my master password the first time. Because of the synchronization issue. I don´t use the same account on my Webdav. Edited July 15, 20224 yr by compoundbow83
July 18, 20224 yr Hi @compoundbow83 We are looking into the concerns reported by you. In the meantime, could you please share the version of the OS and also try disabling and then re-enabling the Touch ID in your Enpass Mac app to check if the issue persists? If you are getting any error, kindly share a screenshot of it as well. We appreciate your co-operation in this matter.
July 18, 20224 yr My OS Version is 12.4 I have disabled and then re-enabled Touch ID, but even then the same problem, I verify myself with Touch ID then still have to enter my master password. When I enter the master password for the first time, the message "wrong master password" appears, if I enter exactly the same password again, it is accepted. I have test without Touch ID, the same issue with the master password. When I enter the master password for the first time, the message "wrong master password" appears, if I enter exactly the same password again, it is accepted. I don't see any error other than "wrong master password". I have an other error. If I close Enpass completely and open it again, I have to unlock my Pro version again
July 19, 20224 yr Hi @compoundbow83 I have forwarded this concern to our dedicated team. As soon as they update me regarding this matter, I will notify you. Your patience in the meantime is appreciated. #SI-2997
July 20, 20224 yr Hi @compoundbow83 We were able to reproduce the concern reported by you, due to which the touch ID is not working for you, and Enpass is not accepting the master password on the first attempt in Mac. Our dedicated team is working on resolving it, and a patch addressing this issue will be released soon. Regarding having to authenticate your Pro license again after completely closing the app, kindly DM me the email address to which the license is linked and the system details on which you are facing this issue. I will then have it investigated for you.
July 22, 20224 yr Thanks for the intermediate information. I look forward to the update. I have send you the DM for the Pro license problem. Edited July 22, 20224 yr by compoundbow83
August 19, 20224 yr The issues under Mac OS: 1. touch ID don´t work 2. currently only one safe can be connected via WebDAV (if I want to connect the second safe via WebDav after the first safe, I just fly out when saving) are still present! When can we expect an update for these two errors? Thanks.
August 22, 20224 yr Hi @compoundbow83 Unfortunately, I will not be able to share any ETA for the same. Rest assured that our dedicated team is already working on resolving the bugs, and a patch addressing these issues will be released for future Enpass versions. Apologies for any inconvenience caused to you in this matter.
September 24, 20224 yr Today is September 24th, 2022 and to date no update has been released for the macos version that fixes the updates. current enpass version for macos: 6.8.2 current enpass version browser (chrom) extension: 6.8.0 With the current status, productive work with the app is no longer possible: Touch ID not working The master password must then be entered twice more than one Webdave vault is not possible every time I want to retrieve a password via the browser (chrome) plugin, the message "Authentication passcode" comes up and I have to enter a six-digit code When is the bug fixing update coming out?
September 30, 20224 yr Hi @compoundbow83 We have recently released Enpass app version 6.8.3. Kindly update your Enpass app to the latest version and then share your findings with me.
September 30, 20224 yr I have now update the iMac Enpass App to version 6.8.3 (1150). but even after that, the same problems still exist: Touch ID not working The master password must then be entered twice more than one Webdave vault is not possible every time I want to retrieve a password via the browser (chrome) plugin, the message "Authentication passcode" comes up and I have to enter a six-digit code current enpass version for macos: 6.8.3 current enpass version browser (chrom) extension: 6.8.0 Enpass has therefore been unusable for an iMac for several months. I really can't understand it anymore, you won't solve the known problems with an update?
October 3, 20224 yr Hi @compoundbow83 I have notified our testing team regarding the concerns you are still facing and will get back to you soon with an update. As for "Unable to connect 2 Vaults with Webdav" error, I will require some additional information for a thorough investigation of this issue. Kindly create a demo account of your Webdav and DM me the username, password and URL. We appreciate your co-operation in this matter.
October 7, 20224 yr Hi @compoundbow83 Regarding the Touch ID not working and Enpass not accepting master password on first attempt in Mac, our testing team requires some additional information in this matter - Is there any particular scenario where you face this issue. Like waking device from sleep, or system startup? Are you having multiple users setup in your device with different Enpass Application setup for all users or have multiple Enpass versions(Store and website) set up? Thank you for your cooperation in this matter.
October 7, 20224 yr Hello, the last time you wanted a "demo account" for my web dave and I set it up, it was never used. Before I do my work, I want to know if it's really needed? it is also while working and reopening Enpass. So it has nothing to do with retiring or starting over. It really is every time you open (click) Enpass. No, I don't have multiple users on my MacBook
October 10, 20224 yr Hi @compoundbow83 Thank you for sharing the details. Please try the below troubleshooting steps and share your findings with me - Disconnect All Vault Syncs in Enpass. Manually create a backup of all vaults from Enpass File Menu → Backup. Store this backup file at a local directory on your device. Now in Enpass, Erase Everything from Advanced in Enpass Preferences → Uninstall Enpass from device → Re-install Enpass from Apple Store. Launch Enpass → Select This Mac → Select Backup File → Select the above created backup from local → Restore the data into Enpass. Once Successfully restored, Activate Enpass using their Registered Email ID. After activation, Enable Touch ID from Security Preferences in Enpass. Once done, you can reconnect your vaults to respective cloud service for synchronization. Regarding "Unable to connect 2 Vaults with Webdav" error, please share the requested information so we may proceed forward with the investigation.
October 10, 20224 yr Hello, I follow the 5 steps. And after this everything works fine. I'm pretty sure we did the exact same steps months ago and it didn't help then. But now I'm glad everything is back to normal. Many Thanks.
