June 23, 20224 yr Hey how can I make CMD + # as shortcut. I can only option + command, is there no other option please make it possible Me and anybodyelse who comes as antisubcrption and pro wlan sync refugee from 1Password is heavly used to it.
June 23, 20224 yr Hi @enpasso Depending on the browser you are using, you can set certain shortcuts for your Enpass browser Extension. Kindly refer to this link on how to set up shortcuts for the browser you are using.
June 24, 20224 yr Author Omg how genius! It is so amazing what options are given! I really don't regret the transition from 1Password to Enpass! But can I also make it systemwide? Because in the option panel of enpass the command + option is hardcoded you can only give es input the 3rd letter like command + option + # But I want it also systemwide to work with command + #. In Browser it works now like a charm
June 24, 20224 yr Author When I add Shortcuts over Safari for Safari, I put with my German Keyboard layout command + # he saves it right it works but it shows on screen as common + / I guess the asciicode is taken right, but if you want to "print it" out it is in English layout. It doesn't disturb but if you fix that it looks cleaner, and is less irritating
