July 18, 20224 yr Hello, I am working on Linux Mint 20.3 (Una) which is based on Ubuntu 20.04.4 LTS (Focal Fossa) and my Enpass application constantly crashes. The Linux kernel I'm using is 5.4.0-122-generic and the desktop manager is Cinnamon version 5.2.7. I have already submitted a couple of crash reports. Can you give me any help?
July 18, 20224 yr Did it spill any details if run from a terminal? Ran enpass on mint 20.3 only two days ago, albeit the Edge iso which uses kernel 5.13 but shouldn't matter
July 19, 20224 yr Hi @Björn, Welcome to the Enpass Community Forum. I appreciate your efforts in reporting the presence of this issue. I have shared it all with the concerned team for further investigation. In the meantime, please share the details of the Enpass version.
July 24, 20224 yr Author @Ivarson, I just tried this and it crashed with some output: $ /opt/enpass/Enpass QTextCursor::setPosition: Position '1' out of range But maybe this message is not the cause of the crash but caused by the crash report window itself - cause when I put it into background and get it up front again, the message repeates. When Enpass starts up correctly, I get a lot of this (but this doesn't look harmful): QQmlComponent: Created graphical object was not placed in the graphics scene. @Manish Chokwal , thank you very much! My enpass version is this: $ apt show enpass Package: enpass Version: 6.8.1.1063 Priority: optional Section: default Maintainer: <ubuntu@ip-172-31-32-66> Installed-Size: 82,8 MB Depends: libxss1, lsof, curl, libxkbcommon-x11-0, libxcb-xinerama0 Conflicts: enpass-beta Homepage: https://www.enpass.io/apps/linux/ License: SINEW END USER LICENSE AGREEMENT (EULA) Vendor: Sinew Software Systems Pvt. Ltd. Download-Size: 40,6 MB APT-Manual-Installed: yes APT-Sources: https://apt.enpass.io stable/main amd64 Packages Description: A cross-platform, complete password management solution that securely manages passwords and all other life important credentials like bank accounts, Credit cards, IDs, passport, driving licenses etc. Everything is saved locally on user device and optionally he can sync through other devices using his accounts of Dropbox, Box, Google Drive, OneDrive and ownCloud.
July 25, 20224 yr Hi @Björn, Thank you for sharing the details. I have forwarded it to the concerned team for further investigation. In the meantime, your patience is highly appreciated here. SI-3007
December 9, 20223 yr It's disappointing, it's been several months with this bug. After many years of using Enpass, I am now using Bitwarden. I hope you guys fix it soon.
December 9, 20223 yr Hi @amarcruz Welcome to the Enpass Forums. For troubleshooting purposes, please create a manual backup/set up synchronization for your Enpass data and then reinstall the app. You can refer to the steps under Linux Section in this link to install on your system. If the issue persists, please share the below details with me, and I’ll have this investigated for you - 1. The version of the Enpass app and OS you are using. 2. Is the app crashing for you after a certain step, ie, after editing an Item, creating a new Item, etc? Or is it completely random? 3. Try disconnecting the internet, then launch the Enpass app and observe if the app is still crashing for you. If it is not crashing, then while the internet is disconnected, try removing the cloud account you are using for synchronization, enable the internet and re-launch Enpass to check if the app is still crashing. Also share the cloud service you are using to synchronize your data. 4. Is the Enpass app showing you a crash report after the crash? If yes, kindly share it with me.
