August 21, 20224 yr On ios 15.6.1 using Enpass 6.8.1. 2 vaults. If you create an item in a custom category in a secondary vault, the category counter is incremented, but the item doesn't show up if one shows all vaults. If the view is changed to show only the secondary vault the item shows up.
August 23, 20224 yr Hi @Ivarson, Thank you for reporting this issue. I have shared it with the concerned team for further investigation. In the meantime, your patience is highly appreciated here. SI-3060
September 29, 20224 yr Author I can't seem to reproduce the issue in 6.8.3 for iOS, but the changelog doesn't mention anything about it. Can you verify that this issue is addressed? Edited September 29, 20224 yr by Ivarson
September 30, 20224 yr Hey @Ivarson, Yes, this issue has been addressed in the latest update v6.8.3 for iOS. You can observe it for the next few days and let us know if the issue is reproduced.
September 30, 20224 yr Author Why aren't you more verbose in the releasenotes, you seem to fix more than covered there. At least when there's a PR mentioned in forumthreads like SI-3060... those could be mentioned in the releasenotes, or the issue description. good job anyway. 6.8.3 is way quicker and stable. Edited September 30, 20224 yr by Ivarson
