September 3, 20224 yr When I copy or move an entry from one vault to another, the last modified and created date gets a new timestamp (now). This is not the behaviour I would expect. At least the create date must stay the same as the original entry. What about the last changed password? Can I rely on the password audit anymore?
September 5, 20224 yr Hey @Schtief, Thank you for reporting the presence of this issue. I have shared it with the concerned team to keep created date remain same if the entry is copied or moved to a different vault. In the meantime, please share the Enpass version and OS information. SI-3082
September 7, 20224 yr Author On 9/5/2022 at 1:10 PM, Manish Chokwal said: In the meantime, please share the Enpass version and OS information. Newest stable on every device.
June 18, 20233 yr Author Hey @Manish Chokwal, is there any progress on this? There were several updates from then and still no info. Thanks in advance!
June 20, 20233 yr Hi @Schtief We thoroughly analyzed the feedback you shared and would like to mention that this is the expected behavior. When we move/copy an Item, it shows the time at which it is generated in that particular vault. Rest assured that the password audit will continue to work without any issues for all the vaults.
June 22, 20233 yr Author Okay, thank you! When this is the expected behaviour, I have to live with this.
