September 28, 20224 yr Hello, I did install the latest version of Enpass Windows (6.8.3 1155) and can't activate the Browser Extention. I can't enter the numbers into to the Popup of my Brave AND Edge Browser - Bernhard
September 28, 20224 yr Hey @bernhard, I appreciate you for reporting the presence of this issue. In order to resolve this issue, please try the following steps: Make sure you are using the latest Enpass version and extension. Open Enpass main app → Browser setting → Enable the extension. Open Enpass main app → Browser setting → Review Browser → Select Browser extension → Remove/Delete → Open browser → Pair Enpass extension. You can also try to reinstall the Enpass extension. [Tip: Before using the Enpass extension, make sure its main app is running in the background.]
September 28, 20224 yr Author Hello, a restart of my PC solved the issue, thank you for your response - Bernhard
