September 29, 20224 yr Hi I am using enpass 6.8.3 on iOS16. Nextcloud sync on my Mac is working flawless. In iOS I get the error that the URL is incorrect. What am I missing? Thanks, Fabian
September 29, 20224 yr Hi @fabwal Welcome to the Enpass Forums. For troubleshooting purposes, please create a manual backup of your data on your Enpass iPhone, reinstall the app and share your findings with me. If the issue persists, please create a demo account of your NextCloud and DM me its login id, password and URL. I'll then have this concern thoroughly investigated for you.
September 30, 20224 yr Hi @fabwal Thank you for sharing the details. We were able to reproduce the bug on our end, due to which this issue is occurring. Our development team is now working on resolving it as a priority. Moreover, soon a patch addressing this issue will be released for the future Enpass versions. In the meantime, as a work around, you can follow the below steps - Connect with Webdav. Use https://www.advibe.de/remote.php/webdav/ as the URL field Also for any Nextcloud URL, you can append /remote.php/webdav/ to connect it using Webdav. #SI-3123
October 4, 20224 yr Author Hi @Abhishek Dewan thanks. I am using webdav which is working I was only wondering as Nextcloud was working on desktop but not on iOS. Do you have a roadmap when the fix is released? Thanks
October 4, 20224 yr Hi @fabwal Unfortunately, I will not be able to share any ETA at the moment. However, rest assured that our team is working on fixing it as a priority. Your kind patience and understanding in the meantime are appreciated.
