SSL certificate validation failed.
I get the same SSL validation message (on latest Windows 11).
I updated Enpass to the latest version but still get the same message.
WHAT CAN WE DO TO SOLVE THAT ISSUE?
It's really annoying, I can't access to my PW on that machine.
  • Replies 77
  • Views 53.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I'm getting this too right now. Guess what - I'm on a plane, on a 14h international flight, and paid for in-flight Wifi, which obvsiouly has strong security measures and sniffers, as expected! Ac
  • Have you guys running any network sniffing app? If yes, please close the app and then register Enpass app.
  • Likewise... it's stupid that you can't turn off this check and allow your software to be validated.  If a customer paid for a license, why prevent them from validating the copy?
Posted Images
Here’s a suggestion that may help resolve the problem:
  • Exit the Enpass application completely by pressing Ctrl+Q.
  • Disconnect your internet connection.
  • Reopen Enpass and set it up in offline mode.
  • In the settings, navigate to the browser section and uncheck both settings as illustrated in the image below.
  • Quit Enpass again, reconnect to the internet, and reopen Enpass.
  • Upon entering the Enpass application, activate your license.
  • Finally, reconnect all your vaults with the clouds.
This should help resolve the problem you're facing. Let me know if you encounter any further issues or need additional assistance.
  • 5 months later...
I don't see an option to disable Certificate Pinning on MAC version of Enpass, but I accidently discovered a solution at least for Zscaler. When you disconnect and reconnect to the network (wifi), it takes a few seconds for Zscaler to start redirecting traffic. If you try to register within these first few seconds - it goes through. Then when you receive a pin, you have to disconnect and reconnects network again and quickly put the pin in. I got it to work this way. YMMV. Good luck!
