November 14, 20224 yr I would like to request for a new field type of "PIN" that acts the same as a password field, but only allows numbers for the field. It should include a random PIN generator. There currently is a PIN field but it doesn't generate PINs like when you select password. Additionally, you can't really use the password field (and rename to PIN) because it doesn't give the option to generate a "PIN" with just numbers. The obvious use case scenario for numeric PINs includes bank ATM PINs and credit card PINs. Edited November 14, 20224 yr by Rojma
November 14, 20224 yr Hi @Rojma Thank you for sharing your valuable suggestion. I have duly noted your comments and have shared with our development team so they may consider it for future Enpass versions. Your cooperation and patience in the meantime are appreciated. #SI-3178
