Prompt for saving passwords not appearing in Android
Hey there,
I am currently using enpass after a friend's recommendedation but i am having too much problem figuring it out!
I am having many issues. One of them is that I am not getting the prompt to save passwords in any web browser i have tried chrome, brave and firefox.
Where as i have tried other password managers also and they work flawlessly in that regard. I get prompt to save password whenever i create a new account or login my existing account.
Enpass version- 6.8.4.734
Android version- 13
Device- Samsung galaxy A33 5G
Edited by BerserkDhanraj
Clarified device type in title
  • BerserkDhanraj changed the title to Prompt for saving passwords not appearing in Android
Update: it doesn't appear on android apps also. Tried logging into netflix and prompt didn't appear on A33 on Android 13 but i got the prompt on another device using android 12
Both devices uses same app version
Hi @BerserkDhanraj
Welcome to the Enpass Forums.
For troubleshooting purposes, please check if you have enabled the “Autofill using accessibility“ option from Enpass autofill settings in your Android device (As shown in the picture below).
114889840_MicrosoftTeams-image(1)-20211229-113343.thumb.jpg.f86ec5fb02a6bb0e760e02e93661f10e.jpg
If the issue persists, please share the version of the browser which you are using along with a few URL's of the webpages/apps on which you are facing this concern and I'll have this further investigated for you.
This is already reported here (reported back in Oct 2022) and Enpass doesn't appear to want to resolve the issue.  You'll be better off selecting Bitwarden as your password manager.
On 1/5/2023 at 4:31 PM, Abhishek Dewan said:
Hi @BerserkDhanraj
I have tried all the troubleshooting methods which are listed on site. Also these options are already enabled.
All browsers which i mentioned are latest upto this date and it is not working on apps also as i mentioned. This is really irritating that it hasn't been fixed from October. Even new password managers works perfectly in that regard.
The most irritating is that it doesn't even works in apps
Quick actions on this issue would be appreciated.
Hi @BerserkDhanraj
Our dedicated team was able to reproduce the reported issue on their end. In addition, Enpass developers have confirmed that future builds will include a fix for this user-reported concern. We appreciate your patience and cooperation while we work on fixing this bug.
I am glad that this bug is fixed now. I really appreciate it.
Can you provide me an eta for next update?
Is new build going to be in beta for testing?
And is fix submitted to play console for review?
Thanks.
Hi @BerserkDhanraj
Our dedicated development team is working on a fix right now. I will be unable to share any ETA but will be sure to update you on this forum when a fix is released.
I'm having the same problem, when I click on my broadway bank mobile app, it no longer prompts me to use enpass. I tried enabling the “Autofill using accessibility“ but all that did was open enpass and I have to look for the name of the institution and copy and paste the pw. I want to to work like before where all I did was put in my finger print and it would automatically fillin the info. I'm not sure if the android update broke this or it just stoped working
my phone
OnePlus 10 pro, android version 13
Thank you
Monica
my phone
Thank you
Monica
I think you are facing totally different issue which is probably reported here.
If that's the case then you can move to page and report the app and all things req to reproduce issue.
