March 22, 20233 yr Many websites cannot be extracted correctly for their icons in Enpass even though I can see them in my browser. I suspect that you are only attempting to extract the "favicon.ico" from the website root directory, right? Could you please also try to extract the data within the "<link rel=icon />" tag on the web page? Let me give you an example. For instance, on https://www.getflix.com/, the website does not use "/favicon.ico" as its website icon. Instead, there is a tag in the meta of the webpage that accesses a PNG image file located in the "/assets" directory. However, it seems that your website icon capture function does not read webpage content. I strongly hope that you can improve in this aspect. Thank you. Edited March 22, 20233 yr by bestpika
March 23, 20233 yr Hi @bestpika Please share the version of the Enpass app, OS, Enpass Extension and browser you are using. I'll then have this further investigated for you.
March 26, 20233 yr Author On 3/23/2023 at 7:03 PM, Abhishek Dewan said: Hi @bestpika Please share the version of the Enpass app, OS, Enpass Extension and browser you are using. I'll then have this further investigated for you. The issue occurs on all versions of Enpass, so it is a version-independent problem. This is a problem with the Enpass main program and has nothing to do with the browser or browser extension. The issue I am referring to is the lack of intelligence in your application's ability to retrieve website icons when creating new items. Edited March 26, 20233 yr by bestpika
March 27, 20233 yr Hi @bestpika Thank you for sharing your valuable suggestion . I have forwarded your comments as feedback to our development team so they may consider it for future Enpass versions. #SI-3319
