Autofill not working on local address
I'm a web developper and I use Enpass frequently to login on my local app with different test accounts.
One of the last version of the app broke the autofill on local website (when the exact same build works on the remote URL).
Environment:
  • OS: macOS Monterey v12.6
  • Browser: Google Chrome v111.0.5563.64
  • Chrome extension: Enpass Password Manager v6.8.3
  • Enpass version: 6.8.5 (1256) Mac App Store
PS: the issue is also present on another computer with Windows 11
Scenario:
I prepared a scenario you can reproduce on your side too. I used the RealWorld demo app so that you can reach it remotely and run locally as well.
  1. Create an entry in enpass with the following. Note that I created this account on the app:
  2. Go on the login page on the remote website: https://demo.realworld.io/#/login
  3. Select the account
    The autofill works as expected. ✅
  4. Now open a terminal and run
    git clone https://github.com/mutoe/vue3-realworld-example-app.git
    cd vue3-realworld-example-app
    npm install
    npm run dev
  5. It should download, install and run the RealWorld demo app locally. Now reach the address displayed in the terminal. For me it's http://127.0.0.1:5173/
  6. Go on the login page and select the login proposed by the extension
  7. Nothing happened. The field is not filled as expected ❌
Thanks for your help,
Aurelien
Hi @aurelien.rasse
Welcome to the Enpass Forums.
I have forwarded this concern to our dedicated team and will get back to you soon with an update. We appreciate your patience in the meantime.
#SI-3318
Hi @aurelien.rasse
We have reproduced the bug on our end due to which this issue is occurring. Our dedicated team is now working on resolving it and soon a patch addressing this issue will be released. Thank you for your patience in the interim.
  • 4 weeks later...
Any update on the matter? I am in the same boat, web developer who frequently Enpass with `localhost` and this breaks the workflow hard.
Edited by Blackfox
Capitalize Enpass name
Do you have some news about this issue? It's been one month now and I can't wait for this bug to be solved!
Thanks
Hi @aurelien.rasse
Our development team is aware of this bug and they are working on fixing it. I will be unable to share any ETA at the moment but will be sure to update this forum once a patch addressing this issue is released. We appreciate your kind understanding and patience in the interim.
  • 2 weeks later...
  • 4 weeks later...
  • 2 months later...
Same old, any update? It's been almost whole summer something that used to work no longer does.
  • 1 month later...
Hi @all
While addressing this bug, we have determined that the autofill failure is linked to a protocol change in this scenario. To resolve this issue, could you kindly save an alternative URL with the 'HTTP' protocol in your Item for locally served websites and then share your observations with us?
Indeed, it works!
Finally a solution, I'm gonna save a lot of time.
Is this because the domain name is matched only with HTTPS by default? If yes, would it be possible to add a setting to allow matching over HTTP too?
Thanks,
Aurélien.
Hi @aurelien.rasse
I'm glad to hear that  this issue has been resolved for you!
Moreover, we are also working on a fix for HTTP pages which will be available in the future versions. We request you to kindly bear with us until then.
  • 2 weeks later...
On 9/22/2023 at 1:55 PM, Abhishek Dewan said:
Hi @all
Could you expand a bit on how to achieve this? I have added multiple versions (screenshot attached) but still not getting completions. 1204396983_Screenshot2023-10-11at17_16_38.thumb.png.cf92b41d73a6c42e38bf29cb1042d796.png
  • 2 months later...
I'm here to complain about how this isn't working yet, running 6.9.3 1591. ETA?
