April 25, 20233 yr Hi there, recently (few months ago) I noticed that navigating on web pages with TAB (which should normaly "jump" over active elements like links, buttons and form inputs) is not working properly. It works normally until it jumps on a form elements (e.g. search, which has many sites), then it cycles up on them. Even this page (Create new topic) is suffering with this issue. I found out that if I turn off the Enpass extension its started to behave as expected. My setup: Enpass 6.8.5 (1256) (Mac App Store) macOS Ventura 13.3 (22E252) primary browser Firefox 112.0 (but behaves the same in Safari and Chrome) Thanks for looking into it.
April 25, 20233 yr Hi @Petr For troubleshooting purposes, please try the below steps - Kindly check that you have the latest version of browser installed. Also, try re-configuring the extension, and reinstalling it from here. Try clearing the cache and cookies of the browser. If the issue persists, please share the below details and I'll have this further investigated for you - The version of the Enpass Extension you are using. The URL of the webpages on which you are facing this concern.
June 8, 20233 yr clearing the cache worked for me. https://tutuappx.com/ Vidmate Edited June 11, 20233 yr by labefat181
