May 30, 20233 yr When you add new item on Enpass you get pre-defined fields. Request to be able to EDIT those field names and field types
May 31, 20233 yr Hi @flyingbirds I have duly noted your comments and have shared them with our dedicated development team so they may consider this feature request for future Enpass versions. Your patience in the meantime is appreciated. #SI-1567
