June 15, 20233 yr Hello, I have several vaults (about 30) that sync on a share located on a Synology NAS server, I use this folder to sync two different computers. From time to time I get a message telling me that there's a problem syncing and if I go to check the problem I'm told that the folder pass mode is required because it would have changed... but I've never changed any password on either my nas or enpass
June 15, 20233 yr Hi @Der43e Please share the version of the Enpass app and OS you are using and I'll get this investigated for you.
June 16, 20232 yr Author Hello and thank you for your reply, I'm on windows 10 22h2 on both machines and the enpass version is 6.8.6 (1360). if you need a log or anything else, don't hesitate to let me know! Edited June 16, 20232 yr by Der43e
June 20, 20232 yr Hi @Der43e Thank you for sharing the requested details. I have forwarded this concern to our dedicated testing team for a thorough analysis and will get back to you soon with an update. Your patience and cooperation in the meantime are appreciated. #SI-3377
