July 7, 20233 yr Currently Home, Favorites, Credit Cards and Identities are the only categries available in the left Side Bar. How do we add more?
July 7, 20233 yr From what I see on my Enpass it's all dependend on the categories you put your entries into. Then at the "Category" part you have 3 dots where you can choose which to show.
July 7, 20233 yr Author As far as I can see, only Home, Favorites, Credit Cards and Identities are visible. There is no option to select categries to be made visible
