July 12, 20233 yr Hello Friends: This is my very first post. I'm a brand new Enpass user looking to vacate my old password manager for this one. On my Fedora-38 Linux server I have the following Enpass version installed: enpass-6.8.4.1167-1.x86_64 (latest) I'd like to use this server as my Enpass WIFI-Sync Server but in a headless setting -- i.e. without having to log in. I can, say, log in a first time to set Enpass up via the its UI, but after that I'd like to run this as a daemon/service every time the system boots without me having to log in and start the desktop UI: /opt/enpass/wifisyncserver_bin Is it possible to set things up this way? Thank you in advance. Edited July 12, 20233 yr by NYCeyes
July 12, 20233 yr Hi @NYCeyes We appreciate you sharing your valuable input regarding this matter. I have also duly noted your comments and shared them as feedback with our dedicated team for further consideration. #SI-3395
July 12, 20233 yr Author Hi @Abhishek Dewan That feature would be a game changer: A file with credentials and key is placed in a secure location with tight permissions. Environment variables point to resources needed: credentials file, Vaults, etc. Then, Linux systemd(1) starts the WIFI-Sync Servicer. No terminal or desktop is needed. Clients connect to it and sync. We headless solution is needed. Edited July 12, 20233 yr by NYCeyes
